NI TestStand
pass cluster through DLL to Teststand
Thanks Julien,
my custom data types are set as mentioned in the document. 1 Byte packing & Labview  string & labview ARRAY.
i tried to close most of the points but  someewhere some issues are there
Message 11 of 15
(2,466 Views)
Have you already set the right string length?
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
Message 12 of 15
(2,462 Views)
Ja
Message 13 of 15
(2,460 Views)
aparab,
I believe I've gotten this working. The primary issue was with passing the Time Stamp data type from the DLL into TestStand. The Time Stamp is not well-suited to being passed in a DLL; see this forum post for more details. I changed your LabVIEW VI to use a string for the timestamp, although a numeric double might be easier to work with in TestStand depending on what you are trying to do. After making this change and rebuilding the DLL, everything worked properly.
As a side note, you probably need to change the numeric format of your custom data type on the C Struct Passing tab of the custom data type properties. The numeric values in your DLL header are defined as int32_t values, which are signed 32-bit integers. Your custom type seems to have these numbers defined as 64-bit real numbers, so your actual numeric data will be very incorrect unless you change the types to be 32-bit signed integers.
I hope this helps, and let us know if you continue to have trouble with it.
Message 14 of 15
(2,440 Views)
thanks Daniel
Message 15 of 15
(2,438 Views)
