NI TestStand
pass/fail in a teststand pop-up
Hi guys, Can I do a pass/fail test in a message pop-up? When I click OK I want a pass and Cancel a fail.
(8,964 Views)
Hey JoVMo,
Couple thoughts:
1- Set Button 1 to "Pass" and Button 2 to "Fail".  Paste the following in your post expression: Runstate.SequenceFailed = (Step.Result.ButtonHit == 1 ? False : True.
Paste the following in your status expression: Step.Result.ButtonHit == 1 ? "Passed" : "Failed".    This should do the trick.
2-  Create a codemoduel (LV, CVI, etc..) that acts like a popup.  Call it as a pass/fail test step.  If the user clicks Fail then return that as the Pass/Fail trigger.
Hope this helps.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(8,924 Views)
Jus this would do the work.
(8,593 Views)
