NI TestStand
passing a string from c# to RunState.Root.Locals.UUT.SerialNumber at NI
HI all,
How can I pass a variable content as a string in c# to the sequence variable named as RunState.Root.Locals.UUT.SerialNumber.
The main gold is to pass the string value from textbox in c# GUI to the sequence parameters.
Tnx
Message 1 of 11
(6,534 Views)
Please check this example :
TestStand 2012\Examples\AccessingPropertiesUsingAPI\UsingDotNet\AccessingPropertiesDotNet
It shows how to set a TestStand Variables from a C# enviornment.
Hope this helps.
Message 2 of 11
(6,517 Views)
Hi all,
I'm using C:\Users\Public\Documents\National Instruments\TestStand 2013\UserInterfaces\Full-Featured
and I'm trying to get the sequenceContex object :    SequenceContext s= axExecutionViewMgr.SequenceContext;
I always get exception "You must pause the execution."
How should I do that??
The main gold is to set RunState.Root.Locals.UUT.SerialNumber at run-time by using c# application(full-featured example).
Message 3 of 11
(6,512 Views)
Use an User Interface Message (short UIMsg) to query the DUT serial number in the Pre-UUT callback.
Norbert
Norbert
Expert: Geometry
Message 4 of 11
(6,508 Views)
Hi Norbert,
I don't need to query the serialNumber ,I need to set the serialNumber at runTime.
On Full featured GUI project I don't know how to access to serialNumber runstate variable.
I'll appriciate your time.
Message 5 of 11
(6,483 Views)
at which time/state in the process do like to set the the number?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 6 of 11
(6,471 Views)
Hi Juergen,
When I start the execution of the sequence I would like to send the serialNumber string from my application(In this case Full Featured GUI example c#) to the RunState.Root.Locals.UUT.SerialNumber variable on NI.
Tnx
Message 7 of 11
(6,468 Views)
Hi
there a serveral ways to do this task. But you should do it in that way Norbert_B has descriped by using UserInterface Messages.
In general, TestStand is not only one process. Your UI is another process. You have to share information over processes.
The recommed way for doing this here is fireing UI messages. From TestStand execution you send a message to your UI. Once you have received this message in your UI, you can get a handle to the current sequnceContext were you are able to set your UUT number.
I am pretty sure that Norbert can explain this more in detail. 🙂 because i am out of time now.
Regards
Juergen
--Signature--
Message 8 of 11
(6,465 Views)
Hi All,
Can someone show me an example that send UI message on C# side
and how to catch the UI message on NI side     ???
Tnx
Message 9 of 11
(6,463 Views)
Hi
Just visit this threads:
For C#:
http://forums.ni.com/t5/NI-TestStand/Modify-local-variables-with-C-dll/m-p/875754/highlight/true#M23...
For Fireing UI-messages:
http://forums.ni.com/t5/NI-TestStand/display-loop-count/m-p/653128/highlight/true#M18182
Regards
Juergen
--Signature--
Message 10 of 11
(6,459 Views)
