NI TestStand
passing array of strings from Teststand to LV dll
Accepted by topic author Madottati
Madottati,
I've attached a 2010 version of the files to this message.
As for the "Array of Strings" option, that would be for a C DLL that was not created in LabVIEW. LabVIEW uses this special format for arrays with the dimension and array data in a struct, so we have to use the custom data type. For a regular C DLL, you can use the Array of Strings option and pass an array in as a parameter normally.
Message 11 of 13
(1,800 Views)
Hi Daniel,
it works fine when I pass array of strings to a labview dll. But it doesn't work in the other direction, if the dll returns an array of strings. TS says:
Expected instance of type LVArray, passed object without type.
Error in parameter 1, 'arg1'.
But I use the same type, as you sent me in the example.
Madottati
Message 12 of 13
(1,749 Views)
Sorry Daniel,
the variable passed from the dll function to TS should also have the type LVArray. Now it works. Thank You!
Madottati
Message 13 of 13
(1,747 Views)
