NI TestStand
passing data on runtime
I have made a small application in VB.Net that adds 2 values. I want to pass these 2 values dynamically (i.e. change these values in every new sequence I run). Please tell me how can I do that. Can I similarly pass some string value dynamically on the run-time?Smiley Mad
Thanks a lot in advance!!!Smiley Happy
Regards
Sreedhar
(2,988 Views)
Sreedhar,
I am not very shure what it is that you're trying to do.  Are you planning on calling your VB.Net application as a code module?  If you are, you could pass the two values you want to add as parameters into the VB.Net code using a .Net Action step.
On the other hand, if you don't want to call your code as code module, you could communicate directly with TestStand engine using the engine's ActiveX API.
Which of these two methods you use depends on what it is that you want to do with VB.Net application.
Santiago Delgado
NIC
(2,962 Views)
