NI TestStand
passing object reference to c#
Hi Doug,
I don't have exception at the following code:
 PropertyObject propertyObject=uiMsg.ActiveXData as PropertyObject;
 GraphPane g = (GraphPane)propertyObject.GetValInterface("GraphPane", 0);
g variable contains null ...
As you mentioned I have to get exception unless it have been managed by the NI code.
Dear doug,
Can you show me a simple .NET example that can be cast and can be referenced by...
Message 11 of 12
(1,841 Views)
@NewSCRUser wrote:
Hi Doug,
Dear doug,
Maybe what's happening is that your variable Locals.GraphPane is actually set to NULL in this case, thus GetValInterface is returning NULL so the cast isn't throwing an exception. Make sure you are actually setting Locals.GraphPane to something and make sure that your UIMessage is posted synchronously (i.e. pass true for the Synchronous parameter).
Also you could re-write your code as follows to test this theory:
 Object gObj = propertyObject.GetValInterface("GraphPane", 0);
Debug.Assert(gObj != null) // If the assert fails you must not have set the local varible or the UImessage is not being posted synchronously.
GraphPane g = (GraphPane) gObj;
-Doug
Message 12 of 12
(1,835 Views)
