NI TestStand
passing the path name of a sequency
I'm trying to pass the application path. If for example my sequence is installed at c:\test\sequence.seq, I could do this as followed in visual basic : App.Path & "\sequence.seq". Here App.Path would contain c:\test.
Is there a way I can do this in teststand 4.0?
(2,990 Views)
Here's how I did it:
Left(RunState.SequenceFile.Path, Find(RunState.SequenceFile.Path, "\\", 0, true, true) + 1)
RunState.SequenceFile.Path is an API call that returns the full path of the current sequence.  If the sequence has never been saved then it returns "".
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,966 Views)
Thank you,
this was very helpfull.
(2,946 Views)
