NI TestStand
path constant paste
When I copy and paste a path from window explorer into teststand as a constant, I need to add an extra "\" in front of all the "\" manually.  Is there a quicker way?  Thanks!
Kudos and Accepted as Solution are welcome!
(4,426 Views)
Accepted by topic author jyang72211
You can prefix string expressions with the @ symbol to prevent backlashes from being interpreted as escape characters. Example:
@"c:\foo\bar\sub1\sub2\sub3\finally.txt"
(4,424 Views)
Exactly what I am looking for.  Thanks!
(4,407 Views)
