NI TestStand
pop-up message 'OK' button
Hi guys,
Can I link the 'OK' button to another event then a 'button click' like a boolean variable. I want the dialog to dissapear and go to the next step when a boolean variable get 'true' state.
Message 1 of 8
(5,551 Views)
You can use the Post Actions of the MessagePopUp Step and use the 'Use Custom Condition' with something like Step.Result.ButtonHit == 1 which will be TRUE for the first button of the MessagePopUp.
Set the 'On Condition True' to one of the drop down items, eg Goto Step and then select the Require Step. Also set the 'On Condition False' for the required action.
Hope this helps
Regards
Ray Farmer
Message 2 of 8
(5,540 Views)
Actually, I want a Popup message without buttons. And when a certain condition get 'true' state, then the Popup go away. Like a Popup placed in a "While", but then without buttons.
Message 3 of 8
(5,489 Views)
With current MessagePopUp you will not beable the have this with no buttons. Therefore you would have to do your own in a code module.
Regards
Ray Farmer
Message 4 of 8
(5,484 Views)
Is it possible to set the 'OK' button alwayz 'true' even it has no Buttonhit event?
Message 5 of 8
(5,467 Views)
No, but you can set it so that after a timeout the dialog will close.
Regards
Ray Farmer
Message 6 of 8
(5,464 Views)
Tnx Ray, how to set up the TimeOut?
Message 7 of 8
(5,459 Views)
I haven't got sight of the MessagePopUp at the moment, but I think the Timeout control is on the same screen as the other buttons. You just have to enter a value which is in seconds eg enter 10 and this will remove the MessagePopup after 10 seconds which the Active Button activates.  Check the TestSTand Help for more information on the MessagePopup Tabs
Regards
Ray Farmer
Message 8 of 8
(5,451 Views)
