NI TestStand
popup message response
Hello.
In popup response, I would like to have the possibility to write in multiple line.
but if I pressed the enter button on the keyboard, this active the ok button of the popup.
Is that possible to change the line in the response or not (to do a kind of check list) ?
I need to write something like follow in the response on the message popup:
"comment 1
comment 2
And I also need to see it in my report, if I have just one line, it is ok, I can see it in my TestStand report.
But if I write multiple lines, could I see it always in the report.
Alex
(3,169 Views)
Have you tried Ctrl+Enter?
If you really want to have Enter alone as new line command, you can select "None" as default button in the button options settings (instead of Button 1).
Norbert
Norbert
Expert: Geometry
(3,168 Views)
oh damm !!
how I do to not fint it by myself...
but it concatenates the lines in 1 line in the report.
Is there a solution to have multiple lines in the report ?
Alex
(3,162 Views)
