NI TestStand
popups multiple monitors
I am running two monitors on both my work PCs, although the orientation differs ( left and right on one, top and bottom on the other).  I don't know if this is relevent. The problem is that, when I open the properties popup for a custom type, it opens in the background, so that I can't see it.  I then can't access either it or the Teststand edittor. This only happens when the edittor is open in monitor no 2.  When Teststand is open on Monitor 1, the popups appear in the foreground correctly.
(4,272 Views)
What version of teststand are you using? What version of the Windows OS are you using?
-Doug
(4,260 Views)
Win 7 and Teststand 2014 14.0.0.274
(4,238 Views)
