NI TestStand
precondition for sequence and tests within
I noticed that if a precondition is applied to a sequence (step), that precondition is not appllied to the steps within.  I guess you don't always want this behavior, but is there an option anywhere, that if checked, sets the precondition of the sequence to all the steps within it?
(4,473 Views)
You could pass the property Step.TS.PreCond as a parameter to the sub Sequence.
Regards
Ray Farmer
Regards
Ray Farmer
(4,468 Views)
TestStand 4.1.1, LabVIEW 8.6.1, WinXP
I have two subsequence calls A and B with preconditions.  The precondition for A is "!MyBoolean" and the precondition for B is "MyBoolean."  If MyBoolean is false, then I should run the subsequence call A but not subsequence call B, right?  That doesn't seem to be the case.  A and B both run.  Am I misunderstanding how preconditions work?
(4,138 Views)
I don't understand what you are getting at. If the precondition for a sequence call returns false, none of the steps in the sequence are run anyway because the sequence is not called. Thus I don't understand the need for the functionality you are asking for. Please explain why such a feature would be needed.
-Doug
(4,133 Views)
This is not how things should be working. I suspect there is additional code in your sequence leading to this unintended behavior. If a sequence call's precondition is false, the sequence should not be getting called. Can you attach an example sequence to illustrate the unexpected behavior you are seeing (ideally, one which doesn't require any code modules).
I created a simple test sequence with a sequence call with the precondition set to false and it did not call the subsequence, it was instead skipped as expected.
-Doug
(4,132 Views)
I think I found the problem.
The precondition is evaluating a boolean.  If the precondition is
MyBoolean
or
!MyBoolean
  ...it doesn't work correctly.  Apparently, the precondition must be expressed as
MyBoolean == True
or
MyBoolean ==  False
-Mark
(4,124 Views)
MyBoolean
or
!MyBoolean
MyBoolean == True
or
MyBoolean ==  False
-Mark
What you are describing is not expected behavior and not what I'm seeing.
I made a simple sequence with two sequence calls and a local variable, Locals.Foo set to false.
If i make one of the sequence calls have the precondition:
Locals.Foo
and one have:
!Locals.Foo
TestStand correctly only runs the one with the precondition !Locals.Foo.
Therefore I still think the cause of your problem is something else. Probably the easiest way to get to the bottom of this is if you can post an example sequence illustrating the behavior you are seeing.
Hope this helps,
-Doug
(4,109 Views)
