NI TestStand
problems with IVI driver when using the 2. channel of agilent E3649A
when I switch the IVI driver to "channel 2" the following error meassage occures:
An exception occurred calling 'RunStep' in 'ISubstep' of 'TestStand Ivi Step Types'
An error occurred while executing the step.
Component Works IVI Control Error: The IVI Configure operation failed for logical name 'UT_Supply1'.
Details: Channel name specified is not valid for the instrument. (CHANNEL2)
Source: TSIviStepTypes
-31617; User-defined error code.
what is the problem?
regards
samuel
(3,103 Views)
hello samuel,
can you take a look at this thread.
maybe this helps you further ...
regards,
robert h
national instuments
(3,082 Views)
