NI TestStand
programmatically export properties
Hi glennjammin,
     I am looking one of the sequence file that you have posted i.e ("RW_From_File.seq"). When i execute the sequence file it works perfect but when I write a new variable in "test.txt" using "FileGlobals.Write("Text.txt","FileGlobals.test1",0)" Api, TS writes in test.txt file.
    My problem is how to read back the Fileglobal variable "test1" and store it in out variable ? I am reading using FileGlobals.Readex("Test.txt","FileGlobals.test1",0). When TS executes Readex step it throws an error.
   Please modify your sequence file by adding 2 flieglobals and reading it back using readex api. or let me know where I am doing mistake.
krishna
Message 11 of 11
(1,221 Views)
