NI TestStand
programmatically transform xml report using Labview
Thank you for this VI!
It did not directly work for me on Windows-10 - but then i changed the ActiveX Call to "MSXML2.IXMLDOMDocument3" and the file-writing to standard VI-Functions.
Then it worked perfectly!
Message 11 of 12
(401 Views)
Can you please share your VI?  I'm running into the same problem, but when I try to change my ActiveX from MSXML2.IXMLDOMDocument2 to Document3, it keeps reverting back. Having never hooked up an ActiveX component to a VI, I'm sure I'm just doing something wrong.
Message 12 of 12
(304 Views)
