NI TestStand
property browser centering
In the attached bitmap, I show a label that I want to use for various user updates.  I'd like the text to show up in the center of the label.  Is there an easy way to do that, or do I have to turn on WordWrap and insert a bunch of spaces till the text is positioned where I want it.  If I have to do that, is there a formating short cut I can use instead.  I'll want to replace "IDLE" with other strings thoughout the test.
(3,078 Views)
Hello mrbean,
There is  no way to center the text vertically and horizontally on the label.  I think that adding spaces or carriage returns would be the best way to get it centered in the label.  If you would like, I think that this would be a great thing to make a product suggestion on.  I will also pass this feedback on.  You can submit a product suggestion here:
Product Suggestion Center
NickB
Applications Engineering
(3,023 Views)
