NI TestStand
prototype for a .net dll
This should be a relatively simple question to answer.
I have a function in a class and need to know how to pass the sequence context. My function is entering when I only have the parameter input, but pestering me everytime I step into it about Teststand not being able to step into the function. When I try passing in the sequence context, I get the folllowing error:
The .NET parameter 'seqContextDisp' could not be accessed.
Unable to cast object of type 'System.__ComObject' to type 'System.UIntPtr'.
I am passing in the field "ThisContext". What am I doing wrong?
Also, there is an entry for Object reference. What is that for? I have "create object" selected. Should I have the entry "Dispose checked"?
namespace
cpp_example_dll {
public ref class Class1 {
   public: void test1_function(TS::SequenceContext *seqContextDisp, int parameter) {
   // How to access the sequence context
   PropertyObjectPtr context = seqContextDisp;
   tst = context->GetValNumber(
"Locals.ThisTest",0);
(3,489 Views)
Hi Steve,
In this thead there is a simple Example
http://forums.ni.com/ni/board/message?board.id=330&message.id=17663&query.id=73821#M17663
Most important hint for writing C# code: THERE WILL BE NO POINTERS, do it with references
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,472 Views)
But I'm using CPP.
(3,458 Views)
Hi Steve,
I assumed your are doing your stuff in C# when I read ".net"
Ok in C(++) you can use your all your pointers.
Just one question. Why are you using the TS/.net Library instead TS/C++ ?
With C++/.net you have unmanaged and managed code alltogether. And most times
you have to marshalling the objects.
Greetings
Juergen
--Signature--
(3,439 Views)
I found out the I was using the CPP libraries and was able to get it to work using the .net libraries instead. CVI is my first choice for anything, but my application requires the use of .net. I'm using CPP because I need features of both.
(3,435 Views)
