NI TestStand
python call teststand engine
I use python and teststand engine to customize solution.But I have some questions about it. 1,code as below: tsEngine = win32com.client.Dispatch("TestStand.Engine.1") print "TestStand %s.%s ready" % (tsEngine.MajorVersion, tsEngine.MinorVersion) tsEngine.UIMessagePollingEnabled = True sequencePath = os.path.join(cwd, 'MySequence.seq') seqFile = tsEngine.GetSequenceFileEx(sequencePath) execution = tsEngine.NewExecution(seqFile, "MainSequence", seqFile, False, 0) execution.WaitForEndEx(60000) execution = None released = tsEngine.ReleaseSequenceFileEx(seqFile, 0x4) seqFile = None #coreleased = tsEngine.ReleaseSequenceFileEx() tsEngine.ShutDown(True) tsEngine = None ## Execution freezes here 2,I need to use UImessage to get pass/fail result of "MySequence.seq".So the first step,I set "tsEngine.UIMessagePollingEnabled = True".But python print these error: Traceback (most recent call last): File "D:\TS_solution\CallTestStand.py", line 39, in released = tsEngine.ReleaseSequenceFileEx(seqFile, 0x4) File "", line 3, in ReleaseSequenceFileEx pywintypes.com_error: (-2147352567, '\xb7\xa2\xc9\xfa\xd2\xe2\xcd\xe2\xa1\xa3', (0, u'TSAPI', u"Unable to unload sequence file 'MySequence.seq' because it is in use, possibly because it is executing.", None, 0, -17213), None) 3,I comment "tsEngine.UIMessagePollingEnabled = True",then teststand pop-up warning windows,show as below: References to PropertyObjects were not released properly. Total number of objects: 53 Number of top-level objects: 13 Note: Some top-level objects may be included if they are referenced by an incorrectly released top-level object. For example, an unreleased SequenceContext object references a SequenceFile object. The following top-level objects were not released: Executions [1 object(s) not released] Type Definitions [2 object(s) not released] Type Definition #1: Name: CommonResults Type Definition #2: Name: Error PropertyObjects [6 object(s) not released] PropertyObject #1: Type: ActiveX Reference Value: Nothing PropertyObject #2: Type: ActiveX Reference Value: Nothing PropertyObject #3: Type: Obj PropertyObject #4: Type: Array of Containers PropertyObject #5: Type: Array of Containers PropertyObject #6: Type: Array of Containers And the following uncategorized objects: UIMessage (TEMessage) UIMessage (TEMessage) Report EditArgs 4,How can I call Teststand API--UImessage class through Python?
Message 1 of 8
(7,651 Views)
Currently, your post is not readable.
You can use code tags to insert code into a post. Juck click the button with the "<>" symbol on it.
Message 2 of 8
(7,598 Views)
I reedit my issue in my reply.Thanks very much for
1,code as below:
execution = None
seqFile = None
Type Definition
Report
EditArgs
Message 3 of 8
(7,483 Views)
I reedit my issue in my reply.Thanks very much for altenbach's remindding.
1,code as below:
execution = None
seqFile = None
Type Definition
Report
EditArgs
Message 4 of 8
(7,483 Views)
Hi, have you find a solution for this issue?
I am currently facing the same problem.
Message 5 of 8
(5,059 Views)
It's probably a bit late now but I had to create a handler for UI messages in python with the win32com module. So I'll share my solution in case it can help anyone...
All you need to do is call the "WithEvents" function of win32com.client like this :
tsEngine = win32com.client.Dispatch('TestStand.Engine.1')
tsEngineEvent = win32com.client.WithEvents(tsEngine, EngineEventHandler)
EngineEventHandler being a class dedicated to the handling of the messages  :
class EngineEventHandler:
    def OnUIMessageEvent(self, uiMsgEvent):
It could probably also work with the DispatchWithEvent function.
Although technically this is more a win32com question than a Teststand API one. And I guess this is not exactly the place to ask this.
Message 6 of 8
(2,920 Views)
I stumbled over your post and it was that I had been searchnig for.
Unfortunatley the approach coruppts my win32com cache and the whole api is not functional anymore.
Did you ran into something similar?
Message 7 of 8
(1,660 Views)
No, or at least I don't remember anything of the sort. We've switched away from Teststand quite some time ago. Sorry I can't be of more help.
Message 8 of 8
(1,613 Views)
