NI TestStand
queston about report headers
I am fairly new at TestStand so perhaps this question has been answered
in the example programs database. I am posting this from memory late at
night and may not have all details right, but here goes...We are using
teststand v1.02 (lastest version IIRC) at work to run a series of tests
based on the Test Stand Model sequence file. The only sequence being
modified is MainSequence.
At the top of the generated report (header) shows info such as serial
number, execution time (IIRC), etc. The last item is the UUT status
(passed/failed). Where is this item generated/added in the report (I
would believe in the ReportHeader callback??). I need to modify it.
Thanks.
Michael
michael.pollack@honeywell.com
(3,971 Views)
This is probably too late to help you, but in the Process Model's "TestReport"
sequence calls "ModifyReportHeader" in your file. Is that what you were
looking for? (At least, it's that way in 1.01, I assume 1.02 is similar.)
it.
>Thanks.
>Michael
>michael.pollack@honeywell.com>
(3,971 Views)
