NI TestStand
"Online" massage from TestStand to Labview
HI boys,
I want to show a variable in TestStand "Online" in a Labview Front Panel, I mean, if the value this variable changed, I don't need call this VI again, the variable should be updated by itself.
Of course I can call the VI again to read the new value of the variable, but I think, there must be a smart wey to do it.Smiley Happy
Cabio
(3,366 Views)
Cabio,
first of all, not all here are necessarily "boys"... 😉
Second: VIs only update elements if they are RUNNING (with certain exceptions). So just open a front panel with an indicator and *magically* put in updated values is not the way it will work properly.
I also epect this question to refer to your "progress display" question.
Norbert
Norbert
Expert: Geometry
(3,348 Views)
HI Norbert_B
"boys" is only for funnySmiley Wink
So you mean, it is impossible the variable in TestStand automatic to update, by only once call the VI?
But I think there must be a way to do it. I have tried with User Interface, but it is really hard to understand.
Maybe I should wait a expert to answer the question.
(3,340 Views)
The key for updating values in the UI are "UI Messages". You could use this mechanism also for asynchronuously running dialog VIs, but i wouldn't recommend that. The user interface is the right place for this.
When digging into UI Messages, you have to take care of two points:
a) The sequence has to post them (PostUIMessageEx from the thread class)
b) The UI has to capture them and update the indicator (callback VI, using reference of the indicator to set the value)
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,337 Views)
