NI TestStand
"TS3.0 is not deploying customised search directories"
Teststand2.0 deployment used to distribute Testexec.ini that contains serach directories. In Teststand3.0, testexec.ini is not updated with customised settings while deploying. Please suggest a solution.
Thank you
Papaiah
(3,243 Views)
Hi Papaiah,
You need to add the Testexec.ini file to your work space before runing the deployement utility. Do the same to the stationglobal.ini file too.
Naresh
(3,243 Views)
Thank you Naresh!!!
-Papaiah
(3,243 Views)
