NI TestStand
"To .NET Object" in TestStand LabVIEW Run-time
I have a LabVIEW VI that uses the "To .NET Object" from the Connectivity/.NET folder.  I call this VI from TestStand.  When the LabVIEW adapter is Development, this VI works fine.  When I change the adapter to LabVIEW Run-time, I get the "Unable to load VI...." error.  I can remove everything else from the VI except the "To .NET Object" and I will still get the error in TestStand with LabVIEW run-time. This error only occurs on my deployment PC; I am currently unable to replicate this error on my development PC.
I have tried adding the <vilib>\Platform directory to my search directory (which holds the dotnet.llb that has this VI).
Is there anything else that I could try?
Details: Windows 7, LabVIEW 2018, TestStand 2017
Message 1 of 1
(2,080 Views)
