NI TestStand
"Unable to get standard CVI step module address" error.
We had a third party develop some TestStand/CVI tests for our company and then it was handed back to me to finish up the final details of it and periodically throughout the finishing up process I would get an error stating that TestStand was "Unable to get standard CVI step module address". I could never quite figure out what was causing it and it would come and go. Now I am in the process of distributing the code to the target machine and I am getting this error again with just the engine installed.
Does anybody have any suggestions as to what is causing this error?
Thanks in advance for any help.
(3,026 Views)
It sounds like the problem you are reported is explained in the \Doc\readme.txt file of TestStand 2.0 (Search the document for "step module address"). The suggested solution is also given. Let us know if this entry does not mactch your case.
(3,026 Views)
