NI TestStand
"Unknown variable or property name" error
Hello, im using teststand 2021 sp1 and the problem is the following: im using a custom steptype with some controls and im trying to write a pre-expression to assign a value to one of this controls.
It is a numeric and the name is Step.Parameters.Device_Select. Whenever i try to use this and this control only (there are many others but no problem with those) i get the following warning: Unknown variable or property name "Step.Parameters.Device Select"; If you are certain that the expression will evaluate correctly at run time, you may ignore the error or use th #NoValidation directive to suppress the error.
I double and triple checked the spelling and the labview code of the steptype in question and everything is correct. Anyone got any idea why this happens? and how can i fix it?
thank you
(1,159 Views)
Here is a typo 😉
(1,156 Views)
yeah i meant to write Device_Select. In teststand its written correctly tho
(1,150 Views)
Please clarify:
you are talking referring to a pre-expression (which refers to TestStand) yet your error seems to show in conjunction with LV. Is it that your custom step type actually uses that VI as a PreStep.
Can you provide screenshots of the type definition and the actual code?
This would really help helping you
(1,128 Views)
