NI TestStand
"unable to load labview project" in Deployment Machine
Hi all,
well the Deployment Target works fine on Development machine
But has problem Loading on the Deployment System     "unable to load labview project"
has anyone had similar issues  and  ound a soln.
NI Support  has not responded yet to the solution.
(4,450 Views)
Hi aparab,
I think I will need more information to solve this issue.
You told "NI Support  has not responded yet to the solution." Do you already have a service request number of the NI support?
Can you post your project? Which RT-target do you use? Which hardware?
You can also post a MAX report of you windows computer and one of your target:
1. Start -> Programs -> NI MAX
2. File -> create protocol -> choose technical support and my system (development computer) -> next -> next -> choose path -> next -> finish.
3. File -> create protocol -> choose technical support and your RT-target (real-time system) -> next -> next -> choose path -> next -> finish.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(4,406 Views)
Thanks a lot Suse,
I have the solution
1 Packed all the files as library during deployment
2 have to try  -> the search directories  in the development maschine could make an issue
(4,400 Views)
