NI TestStand
read SVN Tortoise file revision number in teststand
Hii,
how do we read the Revision number(SVN tortoise) of  the Seq file in Teststand .
I Need to log this number in the test protocol
regards
Akshay
(3,609 Views)
I do not know the SVN command lines very well, but with TortoiseHg for Mercurial we use a "Call Executable" step with the following command line:
hg identify --num "PathToRepository"
catch the output in a Local string variable using the "Output Destination: Store in Variable/Property" setting on the "Standard Output/Error" tab of the "Call Executable" settings and parse that in the PostExpression by
Locals.StationRevision = Trim(Locals.StationRevision,"\n")
to have the RevisionNumber in a Local variable (which is a string in this case, but could be converted to a number using Val()).
Hope that helps.
Peter
(3,601 Views)
Hello aparab,
you can try
"C:\Program Files\TortoiseGit\bin\TortoiseGitProc.exe" /command:log "path to SVN working directory"
Appendix D. Automating TortoiseSVN
best regards
Alexander
(3,550 Views)
This question relates to svn only, and I wrote a simple project to back svn repository years ago.
You could try the command svnlook youngest
(3,537 Views)
Hii all,
thankyou all for your helpfull suggestions.
I will start in LIFO (lastin first out)
1. svnlook youngest <filepath> unfortunately does not provide the Rev. No. , i have gone through a literature suggesting it works on Server side. But my machine is a Client thts the Logical  explannation i could find.
2. TortoiseGitProc.exe  my SVN Client does not include this Executalble.
I will post my soln.. later
regards,
Akshay
(3,531 Views)
"/c svn info "+RunState.SequenceFile.Path
gives me the result almost, well it dumps all info including Rev. number. but seems fine.
(3,528 Views)
