NI TestStand
read the device
how to read the datas from moxa device (i.e)server using teststand
(4,310 Views)
TestStand generally does not talk directly to devices.  That is usually done with a code module.  However, you can call DLLs directly from TestStand.  So if the device has a driver that is a dll you could call that as a code module from TestStand.
So the layers would generally look like this:
TestStand
Code Module (LabVIEW, C#, DLL, etc..)
Driver
Device
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,304 Views)
Got this on the forum :
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/how-to-talk-to-nport-5150-from-moxa-com/td-p/...
If you install the device drivers from the vendor you should be getting the required DLL.
TestStand will be able to call the functions in this DLL.
Ravi S
(4,288 Views)
thanks ......it works....
(4,270 Views)
