NI TestStand
recommend stable Teststand version
Hi, everyone
Can you recommend me  stable teststand and labview version that can be compatibility with Win10 64 bit system.
Now I am use the teststand 2014 and labview 2014, I think this version is not stable as teststand would be shut down when i use the labview to write something in system disk. I think the most problem is that the teststand is not compatibility with Win10 64 bit.
I hope to hear from you soon!
(2,188 Views)
Accepted by open28
I would guess the issue is more likely to do with the way you are writing than TestStand itself. I used TestStand 2014 on Windows 10 and didn't experience any issues. But right now I actively use TestStand 2017 32-bit (SP1) and TestStand 2019 64-bit for customers. The TestStand 2017 runs a test for 36+ hours with no issue. TestStand 2019 has also been stable for all the testing that we do.
(2,128 Views)
Thank you for your response.
My issue is that when i use the system exex.vi to call some bat file, it will happen some error. My bat file will write something in the system disk. But after the teststand call labview, labview call the bat file, the call would be stopped and it shows the calll error(you don`t have the permission to write the file).In my opinion, we do not need to set the permission when we install no matter labview or testsand. So Do you have any idea about this issue?
Besides, I know that the labview2014 don`t support win10 after I contacted with NI TECHNICAL support. But I am still confused about the issue.
This is the story why i need to find a stable version.
Anyway, thank you again.
(2,118 Views)
