04-07-2008 07:30 AM
Solved! Go to Solution.
04-07-2008 08:26 AM
Hi mathan,
Can you explain a bit more, what are you expecting to record and playback?
Regards
Ray Farmer
04-07-2008 09:50 AM
Hai ray,
Thanks for the reply. Actually i want to do some black box testing for my device connected via USB. There is one utility named USBCV for doing tests for the device connected to system via USB. I found one sample program. I attached herewith. I need to create one application in teststand which will do all the tests (provided all the supporting dll's and associated functions) continuously for large number of iterations. So if i did the test manually and recorded for one time then we can playback for any number of times. Am i correct? How to proceed further.
Mathan
04-08-2008 06:12 PM
