NI TestStand
record result only if step fails
Is it possible to specify that a step should only appear in the results if the status is FAILED, and not when it PASSED the test?
It looks like you can only enable or disable the result logging for a step!
Thanks!
John.
Message 1 of 10
(7,464 Views)
John,
maybe this article helps you to solve your request.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 10
(7,458 Views)
Have you gone to the Report Options page and just changed the default result filtering expression? Click on the little down arrow and one of the built-in options is 'Exclude Passed/Done/Skipped'. You can enter your own expression or modify the ones that are there. This expression applies to all steps so it works great if you want to report all step failures as opposed to just some of the steps.
Message 3 of 10
(7,452 Views)
Accepted by topic author has00536
If the anwser from Dennis will full-fill your needs then ignore this.
If you want to match a only special step then i would add after this a statement
step which deletes the last Step.ResultList-element on  PreCondition Pass to this step.
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 4 of 10
(7,439 Views)
Thanks all!
I only want to do this for certain steps, and the solution that Juergen offers will work for me!
Thanks again for all your help!
Message 5 of 10
(7,433 Views)
Could you elaborate on the solution for this issue?  I did not understand the solution; a code snippet would be most appreciated!
Daniel
Message 6 of 10
(7,133 Views)
Hi Daniel,
Try this example for elaborate
Hope this helps
juergen
--Signature--
Message 7 of 10
(7,106 Views)
Thanks so much for the help.  I was a little unclear at first - couldn't figure out why there were two RemoveElement expressions; but I then realized that the Post-Expression is the same thing as the main Expression in this case.
Thanks again,
Daniel
Message 8 of 10
(7,092 Views)
This article addressed my problem.  I now know how to remove skipped steps from my report file.  Thanks.
Message 9 of 10
(6,413 Views)
Hi TonyJ,
If you like to remove only a special step,
just take a look to the attached example, where Passed is replaced by Skipped.
If you like to remove all skipped steps, follow Denis's answer.
Regards
Juergen
--Signature--
Message 10 of 10
(6,393 Views)
