NI TestStand
reducing size of huge .seq file
I've a project with a .seq file that is about 4Mb huge.
It is very long to open in TestStand Sequence Editor and also TestExec versions.
I guess there is lots of useless elements for production execution in this file: may be change history is stored inside?
Of course I've first remove any unused step from the sequence.
Is there a method to reduce the size of such a file (and the reduce the loading time)?
Regards
(5,079 Views)
Sequence Files can be saved in Binary, XML and INI file format.
Binary format is the smallest among the three.
Saving the sequence files in binary format will reduce the size of the sequence file. You can change the file format of the sequence file in sequence file properties. You can access sequence file properties in Sequence Editor using Edit >> Sequence File Properties menu.
You can also use Sequence File Converter tool to modify the format of sequence file.
- Shashidhar
(5,048 Views)
Thank you for the tip.
Will binary format save time at open of file along with reducing size of file? most of the time the compressed formats are longer to open due to uncompress actions.
(5,044 Views)
Binary format is both the smallest and the fastest. You can find more information in https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/file-format-options-dialog-b...
- Shashidhar
(5,031 Views)
Size of files reduced by 10:1 ratio and application load seems to be speeded up, you're right.
Thank you for the advices.
(4,996 Views)
