NI TestStand
remote execution
I want  to execute  sequence from ServerComp on 3 Clients by using Remote execution.
Can i do this?
(in the Specify Model>>Edit sequence call >> Remote Execution  i can choose only one host name)
Thank you.
Olga
(3,291 Views)
Hi Olga,
In the Remote Execution Settings (Right click on your Sequence Call step and select Specify Module. Select Run Sequence on a Remote Computer from the Multithread and Remote Execution drop down, then click on the Settings button) you can specify to Specify Expression for Host.
This allows you to use a variable value for the host name (such as a Local, FileGlobal, or StationGlobal).
Hope this helps Olga, let me know if you have any questions.
Dan Weiland
(3,259 Views)
