NI TestStand
remove TestStand 4.0 comments
My TS 3.5 sequence has comments on almost every step ( there are hundreds). In 4.0 this causes the a lot of confusion because there isn't a seperate column. Can I turn off all comments at once or do I have to go through and manually remove them?
kph
(3,556 Views)
Right click in the step list area and select Step List Configurations>>Edit Step List Configurations.  Click the Edit.. button and uncheck Appearance>>Display Step Comments.
If you want to display the comments in a separate column, like in 3.5, goto the Columns page, click the Add button, select Comment from the Type combobox and enter Comment for the Caption.
(3,549 Views)
Thanks, that worked. I never would have found those options.
kph
(3,541 Views)
