NI TestStand
rename variables
I have chenged a variable from StationGlobals to FileGlobals. Now I have to rename the variable in all the steps where this variable is used.
Is it possible to rename the variable in all steps with one action?
regards samuel
(3,261 Views)
Samuel,
What Version of TestStand are you using?
Have you tried the Find and Replace feature.
Do a find for the StationGlobal and Replace it with your FileGlobal.
Edit->Find.
Hope it helps.
(3,244 Views)
You can use the "Find in Files" in the Edit menu item.
Once you have preformed the search you will be able to perform a Replace with on any of the searched items.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,243 Views)
