NI TestStand
replacing Full OI - Launcher.vi
As part of my customization to the TS3.5 Ful OI (LabVIEW version), I wanted to modify the splash screen that normally comes up (Full OI - Launcher.vi).  I made a copy and renamed it, and I call IT instead in the Startup VIs section of my Build Specifications (under the "Source Files" category (I had previously extracted all the OI files from the LLB and placed them into a LabVIEW project so as to allow me to customize/rebuild as needed).  The block diagram stayed identical, I just replaced the TestStand splash with a custom bitmap.  I see varying results.  Sometimes, the entire bitmap I placed on the front panel (which is about 1/2 the size of the TS Splash) appears.  Sometimes, just the bottom 1/3 of the bitmap appears.  I thought maybe it was related to the size of the front panel, so I've played around with the size.  Currently, it's displaying properly, but this makes no sense.  The new Launcher.vi and the Full OI - Top-Level VI.vi have the same parent directory, but they reside in different subfolders (if this helps).  Are there any rules that I'm unaware of here?
(3,093 Views)
Hey MrBean,
There isn't anything else that is being done behind the scenes.  The LabVIEW code is all that is controlling the window opening and closing.  You do need to make sure that the front panel appears exactly as you want it to at run time.  I'm pretty sure your directory structure sounds ok as long as you modified the interals of the VI to represent that change.
One last thing you could check is to make sure your bitmap is not scaling with the panel.  You can right click on the bitmap and make sure this is not set. Could you post a screenshot of what is happening?
Pat P.
Software Engineer
(3,072 Views)
