NI TestStand
report generation failed----error code:-17205; Access Denied.
Hi, All
    i have a trouble about report generation.it seems the error happened at the "write UUT report"--this step is teststand report generation'DLL.
    detail:
    An error occurred calling 'Save' in 'Report' of 'NI TestStand 2010 SP1 API'
Access Denied.. Error writing to file 'D:\program\seq\xxx.xml'.
The file might be open in another application. If file access is intermittently denied, you should try disabling the Microsoft FindFast utility.
    location:Step 'Write UUT Report' of sequence 'Single Pass' in 'SequentialModel.Seq'
    How to fix it?
    Thanks a lot.
BR
(3,689 Views)
Hm, it looks like the file might be open in another application. If you see that file accesss is intermittently denied, you should try disabling the Microsoft FindFast utility.
CTA, CLA, MTFBWY
(3,670 Views)
