NI TestStand
report teststand enable disable
Hi AE's,
I have a question in TS using a labview operator interface....
i want a boolean button to enable or disable programatically the report. Is there a method to control this parameter....
I have tried to post a uimessage and override in my sequence the reportoption (changing the disablereportgeneration parameter), it doesn't work...
Thanks a lot!
(3,282 Views)
Hi kikou,
The easiest way to do this is probably to simply use the DisableResults Station Option.
You can get a reference to this using Application Manager»Get Engine»Station Options»Disable Results in your VI using property nodes / methods.
I've attached a screenshot for your reference.
Hope this helps!
Jervin Justin
NI TestStand Product Manager
(3,259 Views)
Hi
Thanks a lot it works fine ;o)
(3,166 Views)
