NI TestStand
save automatically report at each step
I would like to save the report automitically at EACH step of my sequence file and not at the end of the last step.
Is there some options in Teststand 3.5, that allows to do this?
Cheers
Risotto
(3,117 Views)
The Report Options dialog box allows you to select 'On the Fly' Reporting, does this satisfy your requirements?
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
(3,106 Views)
Hi Steve,
Thank you for your answer.
I don't know if it will work: the problem I had with Teststand 3.0 was that the report "stay" in the memory until the sequence was finished. And the execution of the sequence last... 3 days. Usually after 10 hours, Teststand crashs because there is no more memory.
But I will try it.
Cheers,
Risotto
(3,103 Views)
