NI TestStand
saving results of "selected pass" into MDB
hello everybody.
i am using the TS2 inherent MDB savig of test results.
but it saves only when runnung the whole sequence (F5)
when i run "selected steps" it doesnt save the results
i need both options of savig test results..
thanks in advance..
simon
(3,526 Views)
OOPS, the Title sould be:
saving results of "selected steps" into MDB
sorry
(3,526 Views)
Hi!
You can accomplish this by selecting "Run Select Steps Using -> Single Pass" as opposed to "Run Selected Steps"
This will run the process model which has the code that saves the data to the database.
Good luck,
Marcela
(3,526 Views)
thanks, it saves the results only as UUT_RESULT.
Is it possible to save also as STEP_RESULT
cause somtimes the steps is a measure or pass/fail.
means, i wish to have the step result and uut result
can i do this?
thanks in advance..
simon.
(3,526 Views)
Hi Simon,
By default, TestStand will log UUT results to the UUT_RESULT, and individual step results to the STEP_RESULT table. Are you not seeing any entries in STEP_RESULT?
There are several configuration options that might be set incorrectly that would turn off database logging for individual step results, you'll want to check these:
1) Global setting for databases - Configure >> Database Options >> Logging Options tab: the "Include Step Results" checkbox must be turned ON.
2) Global setting for result recording - Configure >> Station Options >> Execution tab: the "Disable Result Recording for All Sequences" checkbox must be turned OFF.
3) Global setting for result recording for Interactive Executions ("Run Selected Steps...") - Conf
igure >> Station Options >> Execution tab: the Interactive Executions "Record Results" checkbox must be turned ON.
4) Per-sequence setting for result recording - Edit >> Sequence Properties: the "Disable Result Recording for All Steps" checkbox must be turned OFF.
5) Per-step setting for result recording - right-click the step, go to Properties. On the "Run Options" tab, the "Record Results" checkbox must be turned ON.
These are just the ones I thought of off the top of my head. If some of these configuration options are not set correctly, then that would explain why your STEP_RESULT table has no entries.
Another possibility is that the step's results could be programmatically being removed from the ResultList, but that's a whole 'nother ballgame, see the TestStand Reference Manual for information about the ResultList.
David Mc.
NI Application Engineer
(3,526 Views)
thanks, everything ok now...
(3,526 Views)
