NI TestStand
sending a return value without pass/fail message
I'm using the COM adapter to talk TestComplete application.
I have a string value test step to evaluate a return value and determine if it's pass or fail (e.g. return 0 = pass, return 1 = fail).  This works perfectly.
However, I have added another return value (e.g. return 2), the code executed fine, but it keeps displaying that step as "Failed", which is annoying.  Is there a way to suppress this failed message?
Basically, here's what I need to do, return 0= display pass, return 1 = display fail, return 2 = display no message or just display done.
Thanks so much!
(3,313 Views)
The String Value Test step type only evaluates to Passed or Failed.  It does not do a tristate.  In fact any of the step types in the Tests (Pass/Fail Test, Numeric Limit Test, Multiple Numeric Limit Test, String Value Test) will always be pass or fail.  They never evaluate to just done.
The Status Expression is what makes a step Pass or Fail.  Unfortunately with the default steps you cannot change the Status Expression.  You have to create a custom step type to do that.
What are you setting your Step.Result.String to?  Or did you change the Data Source?
Here are 3 options:
1- Create a custom step based on the String Value Limit test and change the Status Expression such that you get your desired behavior
2- Use and Action step and change the Status Expression such that you get your desired behavior.
3- Continue using the step you are using but in the Post-Expression place some logic which turns off the Step.StepFailCausesSequenceFail if you are in return 2 state
http://zone.ni.com/devzone/cda/tut/p/id/4302
Hope this helps
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,304 Views)
Just came accross this as a 4th option.  I did not know about this: http://digital.ni.com/public.nsf/allkb/E3355265AB4DE465862573F1005C0568
I know it's fore a Pass/Fail step type but the concept will work for a String Value Test.
It is actually the best option.
jigg
CTA, CLA
testeract.com
(3,303 Views)
Accepted by topic author ph2
Thanks Jigg,
Yes, this worked well.  I had two returned value set to passed, and one to failed.  Which is good enough for now. I'll try to change one of the "passed" to "Done" later.
Thanks again!
(3,292 Views)
