NI TestStand
sending path containing \N to LabView transletae it to newline
Using TestStand 4.0 and LabView 8.5.
sending a path to the LabView module looking like this
"C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\express\source\I-OAssistantBlock.llb\I-O Assistant Block.vi" Wgeb the path enters the LV path control the \N has been interpreted as a \n.
The workaround using \\ is not in all cases conveiant.
(3,083 Views)
Unfortunately the only way to make it work is;
a) Start with // in your string
b) Convert the string with / to // before passing to the labview
c) make the conversion in with the labview before passing to a path control.
Regards
Ray Farmer
Regards
Ray Farmer
(3,081 Views)
