NI TestStand
sequence as an edit substep type?
I see no way to choose an adapter type of "sequence" when adding a substep for a step type, although every other type is listed (labview, activex, dll etc).  Is there a way to do this?
(3,459 Views)
Hi, goto Configure in the seq editor window and select "Adapters...". Here you can see that the Sequence adapter is hidden. Uncheck the checkbox and you are ready to go. (previous versions of TS did not hide the Sequence adapter)
Regards
Tom Andres Lomsdalen, CTD
(3,449 Views)
That option only unhides that adaptor from the normal "specify module" options, but not when specifying an adaptor for a substep of a step type.  Do you know of any equivalent checkbox for that?
(3,441 Views)
Sequences can't be substep modules. This was an intentional design simplification decision pre-dating TestStand 1.0.
(3,436 Views)
