NI TestStand
sequence compatibility "2.0 patch 1"
Using the TestStand engine "2.0 Patch 1" I am not able to perform a sequence written with TestStand "2.0.1f1".
A message to load it appear me, I answer "yes", but it did not run!
Is there a utility to make a sequence conversion?
Ciao
(2,733 Views)
Gong,
from what you are describing, it appears you might have encountered the situation described on this KnowledgeBase
It discusses potential issues when opening a 2.0.1 sequence with a previous version of TestSTand. Problems are due to the fact that new Types were introduced with TestStand 2.0.1.
If this does not solve your problem, I suggest you explain in better detailed way what messages pop up from teststand when opening a sequence. You could also attach a screenshot, that would make things a lot easier.
AlessioD
(2,722 Views)
