NI TestStand
sequence file converter exe
I am Using Sequence file converter.exe application to convert the sequence data(.SEQ) to XML format. I am clueless where the XML file is saved on the disk.
Could you please help me to understand the functional behaviour of Sequence file converter.exe and XML file location.
Jay
(4,309 Views)
It gets saved back to the same location.  Basically it replaces the file you have selected or changed.  It still has a .seq extension but now you can open it in an XML editor and see the data in the file.  The same goes for the ini option.  Normally sequence files are binary.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,301 Views)
