NI TestStand
sequencefile.seq [Read Only] unload all modules
This is a basic TestStand question.... a version 3.0 sequence file is seqencefile.seq [Read Only] is open and looks, meaning reads, like that in the window title bar, the "Unload All Modules" does not completly unload the for VI editing. I want to completely unload all modules using version 3.0, how is this done. Btw, I didn't write this code, I've done work using TS version 4.0.
I know this cus "Unload..." persist as active if there are still modules loaded. I check the sequence file properties from XP explorer its not marked "read only". I don't see a property in Teststand where the sequence attribute is set to read only. This sequence does allow me to open the VI when I choose "view contents" then right click (opens the context menu) and click "edit vi".
(3,150 Views)
OK, I think this is a network issue... when I open the sequence mention above, I'm doing this from a remote PC. I open the sequence file on the local PC I don't have this issue.
(3,149 Views)
Hello richjoh,
Are you saying that because the Unload all modules option is still available to you that you believe the modules still persist in memory?  Also, can you clarify what you think about the file's read-only nature would affect this behavior?  Finally, can you elaborate on the differences you witnessed between performing these actions remotely versus locally?
Thanks always,
(3,128 Views)
