NI TestStand
sequences and SLOC
Sequences and all the configuration behind them are not trivial.  I have about fifteen sequences to write for some fairly complex UUTs and I need to provide an estimate for that work.  I'm wondering if there are any metrics available for sequences (as there are for LabVIEW and other text-based languages) that can equate to Source Lines of Code (SLOC) or hours?
(3,048 Views)
Hi MrBean,
Unfortunately there isn't a real good method for simply equating any development of TestStand directly into a monetary sum, or even hours of work for that matter. You could try doing something with the number of steps in your Main and Callback sequences I suppose, but generally speaking the sequence development is the most straightforward and quickest part of development.
The customization of Process Models, Operator Interfaces, Reporting, Database collection, etc. tends to be the most complicated areas of TestStand development (at least in my experience). On top of that, because TestStand can use code modules from any number of languages, this development time would be dependant on the language being used (LabVIEW vs C# for example). It may be possible to create some metrics based on these three areas (step number, customization, and code module development time), but I imagine fine tuning these metrics could get messy.
One thing you may want to consider is speaking with our Alliance members and seeing what they charge for a TestStand project on the same level as what you are doing. The National Instruments Alliance Partner program is a worldwide network of more than 600 consultants, system integrators, developers, channel partners, and industry experts who partner with NI to provide complete, high-quality virtual instrumentation solutions to customers.
You can find more about the Alliance Partner Program at www.ni.com/alliance
Thanks MrBean, have a good one.
Dan Weiland
www.ni.com/support
Dan Weiland
(3,023 Views)
