NI TestStand
serial port
This is a generic question about "test system architecture" in terms of how you develop your LabVIEW VIs etc. to work in a Teststand environment...
In a test system there is usually some central computer (PC) controlling numerous other devices (test equipment) which are all connected to it in some fashion.
In a simple application a Teststand "step" (i.e. action of numeric limit test) could run a VI which:
opens a serial port
writes
waits
reads some data
then closes it.
.. and returns to evaluate the numeric limits/results.
This is not a problem to implement. I think this is called a "connectionless" link.
In a system where the piece of test equipment (or even the DUT) is constantly communicating i.e.
streaming data
or a periodic heartbeat message
... where the PC cannot be so slow on the serial link...
What is the best solution/architecture?
My impression is that you would create a serial communication VI (which is always running) and start it initially from an asynchronous VI call at the start of the teststand sequence.
Communication would then occur between Teststand <>LabVIEW VI, using queues.
you could define the rest i.e. messages and data structure/protocol yourself.
Is this correct?
I would really appreciate it if someone could point me in the right direction in terms of example code/application notes...
(4,997 Views)
That is how I've done my test systems.  Usually have VIs that react to my queue data as part of a test step.
I had to do this with a serial port as well as LabVIEW FPGA interface.  Haven't had to worry about any instruments constantly sending data.
(4,994 Views)
