NI TestStand
set default load unload step options
Is there a way to set the default load and unload options in TestStand.  I would like TestStand to have every step I place default to load dycamically instead of preloading.  Is this possible?
Matt
(3,764 Views)
Matt,
you can create Templates with your modified steps (step settings). Drag'n'drop the step in the Template palette and you can use it from this moment in all your sequence files on this machine.
hope this helps,
Norbert
PS: This requires TS 4.x. If you have an older version of TestStand, you have to create custom step type definitions.....
Norbert
Expert: Geometry
(3,763 Views)
Also note that if you set the Sequence File Properties>>Load Option to Load Dynamically, all steps in the file will load dynamically.
(3,756 Views)
