NI TestStand
set number of elements in a two dimensional array
Does anyone know how to set the number of elements in a two dimensional array directly in teststand.
To set a one dimsional array is simple:
SetNumElements( locals.somearray,4)
Is there a method to do this for a two dimensional array?
Sean
(4,347 Views)
From the help file (TestStand 4.2.0):
PropertyObject.SetNumElements
SetNumElements Method
Syntax
PropertyObject.SetNumElements ( numElements, options = 0)
Purpose
Sets the number of elements of a single dimensional array.
Remarks
This method is only valid for single dimensional arrays. The elements in the array retain their values. Use the PropertyObjectType.ArrayDimensions property to set the number of elements in each dimension of a multi-dimensional array.
Parameters
numElements As Long
[In] New number of elements for the array.
options As Long
[In] Pass 0 to specify the default behavior, or pass one or more PropertyOptions constants. Use the bitwise-OR operator to specify multiple options.
This parameter has a default value of 0.
So you could use, for example: Locals.MultidimensionalArray.Type.ArrayDimensions.SetBounds({1,0},{3,4}) to set an array to have three dimensions (1,2,3), each with five elements (0,1,2,3,4).
(4,343 Views)
