NI TestStand
setting requirements on a TestStand step through the API using CVI
I'm generating TestStand sequences using CVI.
I have no problem to create new sequences, new steps, add parameters, set comments...
But I haven't found how to add requirements on a step.
Could someone give me the function(s) to call on the TestStand API to do this ?
thank you
Vincent
(4,208 Views)
Hey VCourousse,
You need to get the Step.Requirements as a property object, Get the Links object from that and then SetValStringByOffset.  Links is an array of elements in the Requirements property.
Here's what it'd look like:
PropObjectReq = Step.Requirments
PropObjectLinks = PropObjectReq.GetProperyObject("Links", 0)
PropObjectLinks.SetValStringByOffset (elementinRequirements, 0, NewValue)
Hope that gets you on the right path.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,185 Views)
Hi Sam,
Thank you for your answer, that's exactly what I need.
Vincent
(4,171 Views)
Hi Jigg,
Thanks for the example!
I was reading the manual on Requirements.  "The Links subproperty of the Requirements prop...."
Well now i know "Links" ist the name it self! I not a link to an object or something like this
 Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,834 Views)
